wireless adapter for Netgear FWAG114 & Hitachi 7590 VisionBook 64k
The subject tells it all. I would like something inexpensive but with a decent range. I'd love to spend $20 but I would go as high as $50.
Any suggestions
Any suggestions
I forgot to add that I am running Windows 98 on it.
Hitachi is going to send my my extra memory card back so I should get the memory up to 128 or 144meg.
Good fast cheap. Pick two.
The FWAG114 will do 802.11a/b/g wireless. However, with the old laptop, you may be able to only find 802.11b cards that will work.
I can't be sure but I think the old VisionBook uses 16 bit PCMCIA cards and will not fit a 32 bit Cardbus wireless card. That's the way it's on my Hitachi E-133T/810 which is similar but older. There are a few odd 16bit PCMCIA 802.11g cards around, but I can't seem to remember or find the model numbers.
For 16 bit PCMCIA wireless cards, I like Orinoco Classic Silver or Gold cards, mostly because I have a pile of them.
This might help with the older cards:
I forgot to mumble why I like the old "classic" Orinoco cards. Under Windoze 98SE and ME, Netstumbler 0.3.30 works very nicely. (0.4.0 doesn't work at all for me). They also have a very convenient external antenna connector with commonly available pigtails.
