Hello,
I wanted to extend the range of my wired network to a few laptops. Here' what I have and where I've gone thus far:
Wired router is D-link EBR-2310 connected to the cable modem and connected to two PCs.
Wireless router is Belkin F5D7230-4 (don't get me started on this thing) set up in access point mode. Then I have a normal ethernet cable attached between a LAN port on this divice and an open LAN port on the D-Link. This is contrary to the user manual, but does not work when in the WLAN port.
Wired D-Link: DHCP Off IP 192.168.0.1
Wireless Belkin: DHCP Off IP 192.168.0.35 WAP-SPK Enabled
Now, on any PC wired to the d-link everything is smooth sailing and I can even connect to the wireless AP's http configuration. On a laptop, connected wirelessly with a static IP of 192.168.0.65 I can connect to either router's http configuration, and ping anything on the network. What does NOT work is anything beyond the network. The laptop cannot connect to web pages or even ping anything outside the network.
I read other setup instructions and they all said to connect the wireless AP's LAN port to one of the wired LAN ports via a crossover cable. I have a dozen cables and I know for certain that two of them are crossovers, but I can't identify which.. haha.
I'm about to pull out my hair here so any help is appreciated.
