I connect to Plusnet and the internet using your Binatone ADSL 2100 router. I have a small wired network of 3 pc's. I am converting to wireless. So far I have added a Binatone WL1100 wireless access point and a wireless LAN PCI card to my main computer. The system works fine but........
- I have to re-set the wireless access point every time it is switched on.
- I am unable to get into the 'guts' of the wireless access point as I do not have the installation disc (and can't find anywhere to get in on the net).
I suspect the problem is due the default IP addresses. The route is
192.168.1.2 and the Wireless access point is 192.168.1.1 If I type this IP into my browser I am asked for a password which I don't have (admin is no good). Any idea's or suggestion, apart from getting a wireless router that is.
