Hello I bought a wireless router to replace my conventional router so I had to create a new (wireless) connection in Windows XP. The problem is that Windows says that the connection has an open access and that it is not secured. So, what do I need to do to make it secure ? I tried using the network crypting key thing but when I do so, the connection don't work anymore and Windows still says the connection's not secure.
Please help me, thanks!
Also, the Internet seems kinda slow conmpared to with the wired router. Any idea what can be causing this ? Thanks a lot!
