WinTFTP Server Pro 3 is multithreading application designed to allow network administrators and users to save, upload and download configuration files from various network equipments. Example like router, VPN devices, smart hubs, network switches, CATV modems, IP Phones, network printers and other network devices which support router TFTP protocol. WinTFTP Server Pro can be used for writing router configuration or firmware files as well. The server application together with the client application can be used to transfer files between computers.
This multithreading server application may be used in very complex network configuration for network monitoring software at all network devices. This include modem configuration CATV TFTP with CMTS systems. Is configured to use up to 4 network card interfaces using a visual interface on display. The freeware tftp client application is included within the installation kit.
Wintftp server free for professionals supports the TFTP Option Negotiation Protocol. The client appends options at the end of the Read Request or Write request packet. It also supports the TFTP Blocksize Option which allows the free client tftp and free server tftp to negotiate a block size more applicable to the network environment.
- Is running on Microsoft Windows XP / Windows 2000 / Windows Vista platforms. * Is a multi threading application which means it can accept and handle multiple tftp router connections at the same time. * Supports up to 4 network interfaces so don?t worry to use it on a machine with more than 1 network interface.Tftp client configuration main window application * Has security option based on IP address access lists and folder access. Although the tftp protocol has no security option, we enhanced our server with IP address access list, folder access and upload/download permissions. * Built in option to change listening port for each server network interface. * Supports long filenames and nested directories. * Supports nick names both for tft server and tftp clients for an easy administration of your tasks. * Log file for later analysis of your tftp traffic. formatting linkConfigured for running on Windows 2000/XP/2003/Vista/2008/7 Windows XP / Windows 2000 / Windows tftp server Vista, Windows 7 tftp server free platforms. We recomand to become registered user following registration link on home page and receive the update information and update software for free.
Install this tftp application and use for unlimited number of files. Multiple files are accepted and multiuser settings and rights. It works for unlimited number of IP, unlimited size of files depending of your OS. Use all features unlimited times for 30 days without any restriction. We have a very large number of visitors and users growing fast every day worldwide online business.
WinTFTP Server Pro 3 is a client server multithread application compatible with TFTP protocol as described by Internet Standard Documents. TFTP protocol is a datagram based protocol (UDP), used to transfer files between two hosts (ex: PC to PC, PC to device, to devices, etc). For more information about the tftp protocol please see links below:
- RFC 1350 - Trivial File Transfer Protocol (RFC 1350 protocol) * RFC 1782 - TFTP Option Extension (RFC 1782 protocol) * RFC 1783 - TFTP Blocksize Option formatting link
All rights reserved. Copyright (c) 2001-2010
