I have had a wireless network set up between a laptop and my PC which has worked smoothly for a couple of weeks. Today when I booted up the laptop I got the message "Windows was unable to find a certificate to log you into the network " on top of my sys tray icon which now has a yellow triangle and exclamation mark on it!
I browsed about and discovered this was something to do with encryption. Up until this problem occuring I hadn't changed any of my router's (SpeedTouch
585) settings whatsoever or on the laptop. I tried putting in a brand new WPA-PSK key into the router then put it into the laptop, but still the same problem happens. I don't know is this is related but when I input the new key into the laptop in Wireless Network Connection Properties>wireless networks>properties>association hit ok then return to that window it has gone back to the router's default key, a 10 digit key which doesn't work. I also tried to repair the connection but that hasn't worked either.I also read that if, in the network properties>authentication, the "enable IEEE 802.1x authentication for this network" box is enabled it can lead to connection problems. But it is unchecked. In fact, even if I wanted to enable it I can't because the entire box is greyed out. Can someone verify if this is where I can fix the problem, how this window came to be greyed out and how to fix it.
So how has this problem occurred and how do I fix it?
Help gratefully received.
Harry
