I am trying to install for one of my grandchildren a Linksys WPC54 GS v.2 Wireless card Adapter with Windows 2000 and have nothing but trouble with it. I downloaded from the Linksys site the latest driver and software v.
2.02 and it seems to install normally, but when you insert the card you cannot connect to the internet.I have my own laptop with a D-link adapter and it connects wirelessly without a problem.
Linksys technical support has also not been helpful, knowledgeable enough to successfully assist.
Maybe someone here has the same configuration and has an answer, I hope.
Thanks in advance
