Our current configuration is a Billion BiPAC 5200G R4 router on an ADSL connection, serving various points within the building with cat5/5e network cabling, and a wireless XP/SP3 laptop. The wireless link employs WPA. One legacy task is supported by a Win98SE laptop which currently connects via a wired NIC and there are no issues.
However due to a relocation of that Win98SE task to another area where cabling is not a practical proposition, we are considering wireless and that is where I am running into problems. If anyone reading this is of a mind to suggest "dump_98" then please don't bother - the legacy issue *cannot* be supported by later OS/hardware.
The W-NIC at hand for the 98SE box is an Enterasys CSIBD-AA, which is reputedly a reasonable device. On the Enterasys site their 7.86 driver release notes state that this card will support WPA under 98SE (etc) with a 3rd party supplicant (I hate that term, reminds me of suppository - maybe that's the idea, something you shove up the backend of your problem area?). The 7.86 drivers were loaded and the card fires up fine, seeing the router with good signal level but obviously no connectivity. Email exchanges with their support regarding potential supplicants was a total waste of time.
So the search for a 3rd party WPA supplicant ("3PS") began. Much deep Googling uncovered numerous prospects and newsgroup/forum threads as far back as 2003. Funk Odyssey and Meetinghouse AEGIS were early (paid) candidates. The Aegis bundle was reported to have success with a wide range of cards, and was also located freely downloadable from a well-known network hardware manufacturer's site - but this failed to install. It was looking for either (both?) of two files which were not present in the driver suite.
Subsequently Wireless Security Corp's free WPA Assistant was tracked but the widely reported link was dead, presumably as a result of WSC's takeover by Cisco. It has been reported that the Cisco 30-day trial bundle still contains that product, and it can be retained after the bundle is disabled at the end of the trial period. I haven't to date gone that route.
There was also Buffalo's Client Manager v2 which was reported to work with a variety of non-Buffalo cards ("don't use v3, it only works with Buffalo cards - get v2"). Searching on their site only revealed v3, but I located a driver download site with v2 (2.21). This seems to be for their Air Station range, but maybe it is the good oil. In the absence of any installation guide, from scouring the .ini files it isn't clear whether this is a complete driver set or just the WPA supplicant.
So to my questions:
- WSC-Cisco. Can anyone confirm whether a currently downloadable trialware bundle will provide the required WPA client side support and remain operative/legal after the trial period?
- Buffalo. Is that Client Manager a full driver suite or just the WPA supplicant?
- Other. Is there another available (preferably free) 3PS that I should pursue?
- Am I better off trying to set up a wireless bridge to the 98 machine's new area and run the existing PC-card NIC?
Thanks for any constructive advice and experience shared.
