Win XP "Wireless connected" balloons
Threaded View
Win XP gives me a "Wireless connected" balloon on the taskbar whenever I
wake up my laptop.  I'm pretty sure it happens when the screensaver is
running too (in this case the computer isn't hibernating or suspended).
I assume the balloon is raised whenever the wireless link is
disconnected and reconnected?  This must mean that the link is broken
for some reason when I leave my laptop...
Is this normal?
Is there a way of turning off this balloon?
Is there a log file in the Linksys router showing connect /
disconnect?
Sam
SamCKayak
brought to you by http://www.wifi-forum.com /
Re: Win XP "Wireless connected" balloons
It is probably in Power saving mode, it goes to sleep to preserve the
battery. You can turn it off in the driver configuration.
System------device manager------network adapters-----select adapter and view
properties
> Is this normal?
> disconnect?
> Sam
> SamCKayak
Site Timeline
