Win XP ICS - DHCP just quits working?
Hello. Please allow me to ask a question. I am very puzzled. Perhaps some of you could shed some light on my current situation.
Scenario: Windows XP Pro with Netgear WG111 USB 2.0 wireless(wifi) adapter. Drivers and applications installed from latest zip file from netgear (wg111_2_1.zip). Native netgear apps not running at all, instead I am using Windows XP's capabilities to manage my wifi network which consist of an ad hoc network with desktop as host and a laptop as the client. I am using Win XP's Internet Connection Sharing (and its DHCP capabilities).
The ad hoc network runs at 11 mpbs (802.11b) and has a wep key.
For 2 weeks everything works fine. Win XP assigns an IP address to the laptop everytime it connects to the ad hoc network, and I can use my broadband internet connection from my laptop. All is good. Getting great range and data transfer rate is great when streaming music from the host desktop.
Then for what seems like totally out of the blue, Win XP does NOT assign an IP address to my laptop anymore. The laptop connects to the ad hoc network, but hangs on 'acquiring IP address' or something like that, and finally times out and gets a default IP address. If I run ipconfig /renew in a command window on the laptop, I get the message that the DHCP server cannot be reached.
Any ideas? Why would Win XP DHCP suddenly stop working after 2 weeks or so?
Please note that if I manually assign an IP address to the laptop, then all is good again. I can see the host and transfer files etc. Since I have other wifi networks at work, I would like to use Win XP's DHCP again at home because I do not want to have to assign and unassign IP addresses all the time (DHCP at work, then manually at home etc.).
Thank you in advance. CHEERS!
Bendit
Have you tried reconfiguring ICS......start from scratch?
Have you had any virus, spyware or trojans?
Perhaps
laptop
message
Airhead
snipped-for-privacy@yahoo.com (Bendit) wrote in news: snipped-for-privacy@posting.google.com:
I would simply get a wired/wireless NAT router and let it be the gateway device and the DHCP server for the network and be done with it and forget about AD-Hoc anything with ICS Windows anything. You'll have less gray hairs that way. ;-)
It's just a lille advice.
Duane :)
Duane Arnold
Thank you for your advice. I am aware of the different hardware components I could purchase to make my situation better. I would like to stick with ICS and my USB radio though, as it is cost effective (when it works!) and reusable (you can just carry the usb thingy everywhere, it's really small and light). Plus, it is now personal, I must conquer that problem or I will lose sleep over it! :) Thanks again for any input!
Bendit
Chuck
New outcome: I had reinstalled all the netgear software and reconfigured 'internet connection sharing' under windows XP pro and all was good again. The desktop was giving an IP to the laptop, I could access the web from the laptop, life was good.
Then again, while surfing the web from the laptop, all stopped working again. I couldn't surf to anything anymore, URLs couldn't get resolved anymore, I couldn't even PING the host desktop (192.168.0.1)! A 'repair' on the network adapter would once again fail on 'acquiring network address'. The host computer was hosed again.
I am now forced to use hard coded IP addresses, and I am writing this message through a remote desktop connection from the laptop to the desktop (which I guess is way more secured in a way since I have to authenticate).
(note that the wireless service on that laptop runs fine all day long at work, without any drops at all)
So that is my story. I am mystified at the ability of my host computer to work for a while (ICS) and then stop and stay broken for what seems like no good reason at all.
Again, if you have any insights, I am all ears.
cheers!
Bendit
Perhaps
laptop
message
working
resolved
computer
Progress: ICS worked for a couple of days again. This time it had functionned properly without re-installing the netgear software. Beats me. I had placed a support call at netgear just for the heck of it. They have free 90 day support with a new product. Because both computers can ping each other if IP addresses are manually configured, they basically told me to go suck a lemon and call Microsoft (regarding ICS).
Bendit
Probably fair enough - its hardly someone else's problem if MS's DHCP implementation is one lemon short of a G&T. The best solution is to buy a router or invest in cheap proxying s/w.
Mark McIntyre
it's worth a try for you, but i find that xp is usually the issue.
check your firewall settings (if you use xp firewall) as that's where
the issue has been when i'm troubleshooting the office computers.
although after the first few weeks of resetting (yes, on more than one
laptop it took me resetting that several times on each) i no longer
have the issue, but when i do - it is someone's firewall.
mediadarling
Thank you for your input. Unfortunately, it is not the firewall, at least what I can see of the GUI.
Progress report:
I run ICS with a hard coded IP address (and gateway & DNS that points to my host with ICS) on my client (the laptop). I have been up and running without any problems. It seems like the DHCP feature of XP Pro with ICS enabled was the problem for me, it totally breaks my connection.
Bendit
Cant recall what I did, but it was something to do with the XP SP2 Firewall. For sure I turned it off to try it, and think I did something with exceptions.
Peter Pan
Hi
I have the same problem. My desktop has got ICS running on it. My
laptop was working just fine acquiring an IP address through DHCP.
Suddenly out of the blue it just stopped working.
I have two laptops at my home. Both same make and same wireless LAN
card (Intel PRO/Wireless 2200BG). Now one of them is working perfectly
fine acquring IP address through DHCP but in the other laptop the DHCP
client has suddenly quit working. therefore i know the problem is not
with the host.
both the laptops run WinXP SP2 whereas the host is just WinXP. also i
did not install any new software on my laptop so i know the DHCP client
did not quit due to some s/w conflict.
Please help. Also if at least anyone can tell me how to manually
configure my laptop for ICS.
thanks
- Sid
siddskapoor
My second laptop's DHCP also stopped working today just out of the
blue... no new software installed... nothing...
My first laptop was bought earlier and it stopped working around 10-15
days ago.. the other laptop was bought later and it stopped working
later.
Seems too wierd. Me totally confused.
You say you had something to do with firewalls.. Was it the host
machine firewall or the client firewall ?
On the host machine i have two Network cards. The first one connects me
to my ISP and its firewalled (it connects to the internet and is
shared). the second one is a wireless one and it is automatically
assigned 192.168.0.1 and it is not firewalled. My computer runs a soft
AP and the wirless lan card connects to the wireless network simulated
by the soft AP.
how is your network working right now?
- Sid
siddskapoor
Well, the usual screwup is that your laptop(s) are associating with the neighbors access point instead of your own. It's sometimes no obvious which access point XP is trying to connect. Right click on the wireless icon in the system tray and force a connection to your own access point. If that works, set your access point (SSID) to the "preferred" connection.
If you wanna have some fun, download and install the free DHCP query tool from:
of list). You don't have to have a connection or IP address to use it. It will find a suitable DHCP server and query it using broadcasts. My guess(tm) is that you'll find you're not querying your own DHCP server, but are connected to the neighbors or something.
Control Panel -> Firewall -> Exceptions tab See if "File and Print Services" is checked.
Jeff Liebermann
I thought you had said you had XP SP2, which has it's own firewall, and has a problem with both it and a 3rd party firewall running on the same machine at the same time (host or client doesn't matter.. does it have a firewall AND sp2 with a firewall?)
Peter Pan
The XP SP2 firwall is fairly smart. It will detect if there's another firewall present and automagically disable itself. If ZoneAlarm, Kerio, Norton Firewall, or McAfee Firewall are present, the XP SP2 firewall turns off.
Jeff Liebermann
My laptop shows just my own wireless network in available wireless
network. And my own wireless network (SSID) is already set as
'preferred'. Does that still mean my laptop may be querying someones else's DHCP
server? Also a while ago one of my laptops was working perfectly fine while the
other one (same make and config) just beside it was not able to acquire
an IP address through DHCP server. So i dont think the problem is that
there is another wireless network in the vicinity.
I do not have any third party firewall. Just SP2 firewall on laptops
and regular WinXP Pro firewall on host desktop. The tool you said - could not make it to work. What would be the device
identifier as asked in it??
siddskapoor
No. You have to see the SSID of the access point before it can deliver an IP address via DHCP. So much for that theory.
Actually, that's exactly the symptoms I would expect from a nearby access point.
Ok. You can have the Windoze firewall fairly badly configured and you should still get a DHCP IP address from the wireless router.
No identifier. What you should see is a list of parameters supplied by your DHCP server. It will have your delivered IP address, the gateway address, and the DHCP servers in the list, along with some other junk. However, no easy way to identify the unit except the magic cookie which methinks is a bit cryptic. If you have two identically configured wireless routers and both with identical DHCP configurations, then you would have some difficulty distinguishing between them. Only the magic cookie will be different. However, in this case, we have nothing, so the problem is elsewhere.
The 169.254.xxx.xxx address is what Windoze XP assigns as an IP address when it can't find a DHCP server. This is normal, but it means that something is broken.
I'm not sure exactly where to start, but methinks reducing the system to its basic parts and defaults is the best approach. I'm a bit lost because you didn't start a new message and mixed your system description with another ICS related issue. It appears that you have two laptops using Intel PRO/Wireless 2200BG cards. You describe your system as: "On the host machine i have two Network cards. The first one connects me to my ISP and its firewalled (it connects to the internet and is shared). the second one is a wireless one and it is automatically assigned 192.168.0.1 and it is not firewalled. My computer runs a soft AP and the wirless lan card connects to the wireless network simulated by the soft AP." Could you disclose?
  1. What wireless device is connected to the ICS server?
  2. Where does it get its IP address? From the ICS server?
  3. Does the unspecified wireless device also have a DHCP server? Incidentally, I would call it an "ICS server" and not a host.
My guess(tm), is that you have an access point or wireless router running as an access point connected to the ICS server. That means that you can just unplug the ethernet cable between the ethernet card and the wireless device, and connect your laptop directly to the ICS server. You may need an ethernet hub or switch to get the cable polarity correct, but it should work without the wireless. If you get a DHCP assigned IP address, the problem is in the wireless setup. If you don't get a DHCP assigned IP address, the problem is in your ICS setup and configuration. My guess(tm) would be the latter.
Editorial remark: ICS sucks. I usually don't bother answering questions about ICS because it's a mess to troubleshoot and make work reliably. The only justification for using ICS is when your ISP forces you to use a USB or PCI DSL or cable modem. Since you have two ethernet cards, this is obviously not the case. I non-humbly suggest you invest in a wireless router, which does NAT, DHCP, security, and all the things ICS is vainly trying to do, remove ICS, and do things the "right" way (usually my way).
Jeff Liebermann
I will try to explain the exact setup of my network:
My DESKTOP has two lan cards -
one is normal LAN card (UTP cable), lets call its network connection as
"ISP"
the other is wireless lan card, lets call its network connection as
"Wi-Fi"
The ISP connection connects my desktop to the ISP. My ISP provides net
connection through a city wide LAN through UTP cables. The ISP
connection LAN card has got IP and gateway as given to me by my ISP
(manually configured). This connection is firewalled (normal WinXP
firewall not SP2) and is shared for ICS.
The desktop has a Soft AP running with a certain SSID. The Wi-Fi
connection of the desktop connects to this Soft-AP (of desktop). The Wi-Fi connection has been assigned the IP 192.168.0.1 due to the
ICS.
Now my LAPTOP: The laptop has just one Wi-Fi Lan card, configured to obtain IP
automatically through DHCP. But its not able to acquire.
I do not have any other hardware like router or hub. I just have
wirless LAN cards and the Soft-AP. I hope the above is clear.
The reason why I am persisting to sove this problem and not buy a
router is cos
  1. The current setup was working just fine and beautifully until 15
days ago.
  1. I may be switching my ISP and the new ISP is going to give me a DSL
USB modem where i will be forced to use ICS.
I have even tried to reset the TCP/IP stack on the Laptops. Havent been
able to try it on the dekstop yet (cos its not SP2). As a last resort i
may re-install my WindowsXP on the desktop and get the SP2 patch done
on the desktop.
Please help.
siddskapoor
siddskapoor wrote in news:1105298994.b73701f350505f7ac39b7c8606ff1bdb@teranews:
That's called the Internet/WAN or public facing network connection.
That's called a LAN or private side facing network connection.
It seems like some people are trying to do this and have nothing but problems.
Doesn't the ISP provide DSL RJ45 jack modems? And besides there is nothing stopping you from buy your own DSL modem with a RJ45 connection. If you buy one, then it should be a brand that's approved to run on the ISP's network. But by doing this, it forces you to support your setup as the ISP will not support it.
Your best solution is to get a DSL modem with a RJ45 connection and use a router if you can and let the router be the gateway device for the WAN and provide the ICS on the LAN. I have seen a few posts made in various NG(s) about the problems with ICS and XP even on a wire setup and losing DHCP on the setup.
Duane :)
Duane Arnold
