I have a system that consists of two mpeg encoders and an embedded PC, all connected to a switch. Each of the three devices has a fixed IP address. A fourth port on the switch goes to a connector for external connections to this system. The fixed IP addresses are as follows:
PC = 192.168.100.52 MPEG1 = 192.168.100.50 MPEG2 = 192.168.100.51 Subnet (all) = 255.255.255.0
I connect a notebook computer, also with a fixed IP address (192.168.100.55), to the external system connector with a CAT5 cable and use it to simultaneously display the two video streams (3Mb/s each) and to control the system.
There is no router nor gateway as the notebook applications each communicate directly to the system components at their fixed IP addresses. This is all functioning properly.
My desire is to set up a wireless connection such that I can use the internal wireless-g adapter on the notebook computer to connect to the system in place of the cable.
I purchased a D-Link DWL-2100AP access point and configured it as an access point with an IP address of 192.168.100.53 and no security. I then connected it to the system switch. The notebook wireless IP address is 192.168.100.54. The notebook computer was able to detect and connect to the wireless access point. However, I could not ping the system components from the notebook nor ping the notebook from the embedded PC within the system.
Any advice regarding this wireless application would be appreciated.
-- David Orlando, FL
