WiFi Router as Client - What Am I Doing Wrong?
Threaded View
OK, I'm using a Zyxel P-330W router essentially as a wireless
card for my computers to conect to the remote wireless access
point.  I understand that this is possible with this router in
client mode.
OK, I can get the remote AP (weakly) with a PCI card in the main
computer and get Internet (flakily).  I've pulled that card.
With the router, I can get a much better wireless connect to the
remote AP, but I cannot get the computer, which is connected to
the router by an Ethernet cable, to access the Internet via the
router to the remote AP.
Intuitively, I suspect that there's something amiss with the IP
assignments.
Here are the readouts from my router's diagnostic screens while
connected to the remote AP.
Can you tell what I'm doing wrong here?
Thanks for any help!
System
Uptime:     0day:0h:26m:49s
Firmware Version:     P-330W_V1.5
Wireless
Mode:     Infrastructure Client   < Should that be "Ad Hoc"?
Band:     2.4 GHz (B+G)
SSID:     linksys                 < that's the remote AP
Channel Number:     6
Encryption:     Disabled
BSSID:     00:16:b6:d7:8f:ab
State:     Connected
LAN
Connection Method:     Fixed IP
Physical Address:     00:13:49:2a:65:3d
IP Address:     192.168.1.1
Network Mask:     255.255.255.0
Default Gateway:     192.168.1.1
DHCP Server:     ON
DHCP Start IP Address:     192.168.1.33
DHCP Finish IP Address:     192.168.1.65
Internet
Connection Method:     DHCP
Physical Address:     00:13:49:2a:65:3f
IP Address:     192.168.1.70
Default Gateway:     192.168.1.254
Wireless ISP Operation Mode
Status
Internet
Internet IP Address:     192.168.1.70
LAN     IP Address:     192.168.1.1
DHCP Server:     ON
System     Firmware Version:     P-330W_V1.5
Connection Details
Internet
      Uptime:  0day:0h:32m:38s
This message was sent via two or more anonymous remailing services.
Re: WiFi Router as Client - What Am I Doing Wrong?
On 22 Jun 2006 09:12:28 -0000, Anonymous-Remailer@See.Comment.Header
No -- Infrastructure Client is what you want.
You probably want DHCP turned OFF, with the router working just as a
bridge, not as a router.
Best regards,   FAQ for Wireless Internet: <http://Wireless.wikia.com
John Navas      FAQ for Wi-Fi:  <http://wireless.wikia.com/wiki/Wi-Fi
           Wi-Fi How To: <http://wireless.wikia.com/wiki/Wi-Fi_How_To
Fixes to Wi-Fi Problems:  <http://wireless.wikia.com/wiki/Wi-Fi_Fixes
That's what I suspected.  Will do.
So, "Wireless ISP Operation Mode" isn't right?
I don't think "Bridge Mode" worked, but I'll try again and
see how it goes later tonight.  There are "Gateway," "Bridge"
and "Wireless ISP" modes available.
Thanks for your help.
On 22 Jun 2006 21:44:13 -0000, Anonymous-Remailer@See.Comment.Header
I don't know what invented marketing phrase really means.
Site Timeline
