Wifi Max help plz!
I have the wifi max for psp/DS n i remember I used to be able to pick up the wifi max signal with my laptop so i could connect to the net with it. The advertisement even says it can. ive tried to load it again n it works for my DS but my laptop isnt finding the signal anymore...any help? thanks!
Tylau2
Where are you running that you have a Wifi max signal ? I'm confused by the term "max" ?
P.Schuman
