I'm sure this is a stupid question but I have yet to find a solution. Is there a utility that will automatically sync selected files/folders between computers once a WiFi computer conects to my WiFi network? Thanks
Yes, there is. It's the same for wireless as it is for wired ethernet newtorks. I'll assume Windoze XP computahs. XP comes with Briefcase, which does a fair job of synchronizing files. See:
instructions.
For MS Office, and other supported applications, there's MS ActiveSync:
is primarily used for synchronizing MS Office databases (contacts, tasks, todo, favorites, and calendar), but can synchronize other things for supported applications.
If these are not what you want, you'll need to specify exactly what you're doing, how you're planning to use it, and exactly what you mean by "automatically".
