My wifi network has been running great with no problems at all, all fully secured using 128bit wep and then the two wired laptops in the house started losing the connections or getting "limited or no connectivity". if i turn off the encryption both work fine, turn it back on and set the passkeys and it will connect perfectly for a couple of minutes then both will lose the connection. (this i have tried using both 128bit and WPA-PSK) Both laptops are XPsp2 and all the kit is 3Com which has worked for almost a year flawlessly. The wired connections are not affected. any help with this greatfully received. Richard
- posted
19 years ago
