Greetings all,
A problem emerged on my Windows peer to peer network, (4 computers,
2 win2k, 1 xp and 1 win98) on the 2 wifi machines (win98 G and xp B clients) No domain, only a workgroup defined with one (wired) master browser (all the other PC's browsers disabled in registry).3COM Officeconnect 3CRWE554G72T 802.11G Router (Also Connected to a Cable modem internet with L2TP). DHCP enabled.
Can't browse the internet with IE on the wifi clients, responds with a quick "dnserror" on the bottom and then a blank page with "page cannot be displayed". Outlook express still works though, and so does the router configuration page. on the wired machines all is well (both browsing and email).
I have the router configured as DHCP server. The L2TP connection to the internet is configured with 2 DNS servers. The ipconfig /all reports:
Ethernet adapter: Media disconnected
Wireless adapter:
DHCP Enabled: yes Ip address 192.168.x.x subnet 255.255.255.0 def. gateway: 212.117.x.x dns servers 212.117.x.x dns servers 212.117.x.x
If I enter a static address in the Wifi notebook it seems to solve the problem, but I think its only temprary until the next lease expires (I have a temp. lease IP). In any case I'd like the notebook to be without static IP so it can roam without a novice user having to change configurations. The 3COM config advises that automatic settings (i.e. not static) should work.
By the way I have WEP 128 bit encryption and router limits to home network MAC addresses only.
Its not any spyware (I scanned) nor Norton NIS that I have since I have it on the wired computers as well.
Thanks for any help..!
