Ok, on the 2nd story of my house in my office I have a WRT54G v6.0. It's running DDWRT... now, in my bedroom about 40 feet from my office I have another WRT54G v1.0 running DDWRT in Wireless Bridge mode as well. have a large glass patio door and looking out of it you can see my workshop, which is a steel pole shed (finished, insulated, etc) about
250 feet away line of site, no obstructions.As far as wifi signal, I can only get about halfway to the shop with a laptop and Netstumbler before the signal isn't good enough. With the router outside of the window, I can get to the door of the shop.
So I bought a 11db flat panel 30deg antenna and tried that. Through the window I can make it about 3/4 of the way to the shop. Haven't tried outside yet. also haven't really tried aiming it yet at all.
Here's the funny thing. In my basement (2 floors down from the main router) I have a Wii and a desktop with a wifi card. On the Pc I get Great signal (all 5 bars in M$ network viewer) and the Wii gets a good signal too. This is through at least 2 floors, maybe even a couple walls.
i plan on trying the directional antenna from the repeater outside, but I thought it would have gave me a little more distance than it did, even through a window. The window actually seems to block more, or just as much as walls.
My goal is to get Wifi to my shop without anything else besides my directional antenna. If not, I'm praying ethernet over power will work. ( have the 102s from Netgear, just don't have power to the shop yet to try it)
I just find it curious that outside of the window I get at least 50% better range than inside of the window. Are some windows just more reflective?
