Wireless Networking wifi 54.g via 11.b card
Subject Author Date
wifi 54.g via 11.b card szefte 04-28-07
Posted by on April 28, 2007, 8:30 am
i am trying [very hard] to get a 16bit pcmcia wifi card for my palmtop
but most of the products are 802.11.b the question is if i can connect
with 11.b card to a 54.g network. i do not have control over acces
point and cannot change it to 11b.
Posted by John Navas on April 28, 2007, 11:46 am
On 28 Apr 2007 05:30:31 -0700, szefte@googlemail.com wrote in
You can connect _if_ the access point doesn't have "b" disabled.
Most don't disable "b".
Best regards, FAQ for Wireless Internet: <http://Wireless.wikia.com>
John Navas FAQ for Wi-Fi: <http://wireless.wikia.com/wiki/Wi-Fi>
Wi-Fi How To: <http://wireless.wikia.com/wiki/Wi-Fi_HowTo>
Fixes to Wi-Fi Problems: <http://wireless.wikia.com/wiki/Wi-Fi_Fixes>
Posted by Eric on April 29, 2007, 7:27 pm
I use a 16-bit PCMCIA (Cisco Aeronet) 802.11b card with my 'ol HP Jornada
720 (H/PC) all the time.
As John already said, most (public) 802.11g AP's are left open to fallback
with 802.11b.
802.11g wireless routers and AP's have an option on whether to allow 802.11b
to work with them or not.
Even if it is enabled, something else that could prevent it's use is
encryption though. If 802.11b fallback in enabled, but it is using WPA,
chances are that you won't be able to use it. Not many (if any at all?)
strickly 802.11b pieces of hardware support WPA.
At home, I use my J720 through an open (captive portaled) 802.11b AP, so I
don't change my 802.11a/g AP's from WPA.
If you absolutetly must be able to use WPA, check hpcfactor.com and see if
there is any 802.11g hardware listed there. It is geared towards H/PC, but
lists 16-bit PCMCIA hardware. There may be such an animal out there.
Probably have to go to Ebay to get your hands on it though. 802.11g won't
give you better "speed" on a palmtop (palmtop is a bottleneck itself) than
802.11b, but would give you WPA if you absolutetly have to have it. Good
luck!
Similar ThreadsPosted
SD WiFi card November 30, 2004, 5:27 am
SMC wifi card with XP SP2 October 30, 2005, 10:27 pm
wifi 54.g via 11.b card April 28, 2007, 8:30 am
I can hear my Wifi card on my TV! January 21, 2005, 1:47 pm
PCI WiFi card with most sensitive RX December 27, 2006, 10:36 pm
Is this possible? Using a WiFi card for 2 connections? January 13, 2007, 4:38 pm
Can I use a router as if it's a wifi card? March 29, 2008, 10:55 pm
Really Need =====> HELP - Hawking HWC54D WiFi Card January 27, 2005, 6:32 am
PCMCIA WiFi card with external ant? June 18, 2005, 12:52 am
laptop WiFi Card Antenna May 16, 2006, 10:45 pm
Slim PCMCIA wifi card November 7, 2006, 4:05 am
installing a wifi card on my laptop March 26, 2007, 4:27 pm
Wifi card in laptop - cannot connect, help! April 7, 2007, 11:55 am
internal wifi card v. USB adapter August 11, 2007, 8:00 pm
Can't get IP to auto assign with Netgear Wifi card February 11, 2005, 2:47 pm
