It will attempt to connect, then within 5 seconds reset to Not
> Connected. Some times the icon on my taskbar for the wireless will
> disappear telling me that the drivers unloaded, then re-appear so the
> drivers had been loaded.
Basically the i cant keep a stable connection to the network with it
screwing up my computer. I try connecting and it's like the wireless
drivers and the XP SP2 Wireless Zero Configuration stop responding,
then i loose connection and have to reconnect. After trying to
reconnect 10 times, then i may get a connection for like 5 minutes
before i stop sending/recieving packets. Still says i'm connected, but
I stop sending and recieving packets.
