I suppose that you have DHCP enabled on your unit. However, I use different access points around the country and run into this frequently. From my standpoint it usually was resolved by somehow adjusting the received signal strength. Moving the antenna around etc. Too little will produce the problem. And it seems to require just the right amount of signal strength to cure the problem when using a strange AP. Luck!!
- Vote on answer
- posted
18 years ago
