I f i use someone's wifi, can he see the sites i am accessing?
- posted
17 years ago
Yes.
Yes
How? Just curious, not doubting...
Thanks.
Several ways, >How? Just curious, not doubting...
Maybe, maybe not.
a) only if he's looking b) only if he looks at the logs afterwards (if they exist) c) not if you establish a VPN and tunnel your way through
David.
Yes, you should assume so, especially if SNMP logging is turned on, or they are using 3rd party software like
