After I attached a USB wirless adaptor on my 2nd desktop kept in the hall way - the modem and rotuter is in a room not far with the door opened - and tested wirless internet connection, I was automatically connected to my neighor's network which has no encryption even though the signal level is a little bit lower than mine.
Q1: Is that because that network has no encryption?
Q2: Let's say, my visiting relative doesn't know about all this and when vsiiting me with her/his got a laptop (that has wirless card) and tried to get online, if the same were to happen, i.e the laptop gets internet connection via my neighbor's network instead of mine, what are the secuirty compromise on my relative's laptop sinee my beighbors network has no proetection? As long as my the laptop doesn't have file sharing capabilty enabled, the laptop is safe, right?
