Wireless Networking why is wireless networking card not recognized after PC turned off ?
Subject Author Date
why is wireless networking card not recognized after PC turned off ? Bob 03-08-08
Posted by Bob on March 8, 2008, 9:29 am
Would appreciate any advice available on this embarrassing dilemma...
My family thought I was a hero when I successfully hooked up my DLink WDA
1320 to allow wireless connectivity to our main PC in another room. Every
time I turn off the PC, however, the system does not recognize that the card
is installed anymore - it's simply not in device manager.
Called the DLInk tech support. They suggested I take the card out and
re-insert. Yes, that works but I should not have to do this every time I
turn on the PC.
How to fix this and restore my hero status in eyes of adoring wife and kids?
thanks
bob
Posted by Jeff Liebermann on March 8, 2008, 12:24 pm
<http://www.dlink.com/products/?pid=475>
>turn on the PC.
Can you supply some clues as to what manner of PC this card is
installed? CPU and operating system would be nice. I'll assume a
some kind of desktop running XP SP2.
Right click on "My Computah" on the desktop and select "Properties".
Select the "Device Manager" tab.
Under "View" select "Show hidden devices".
Do you have more than one listing for the DLink WDA-1320?
If so, you get to unintall multiple versions of the driver. This is
usually the result of walking the board through multiple PCI slots
*AND* reinstalling the driver on top of the previous driver.
It's also a bug in some driver installs. I suggest you download the
latest driver from the DLink web pile and use it instead of what came
in the box.
I don't recall if the install requires that you install the drivers
before or after the card is installed in the PC. Whatever it says in
the instructions, do it that way. If necessary, uninstall the driver,
roll back the computer to it's previous state using:
Start -> Programs -> Accessories -> System Tools -> System Restore
to remove any traces of the driver. This is a bit drastic, but easy
enough to do.
Jeff Liebermann jeffl@cruzio.com
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann AE6KS 831-336-2558
Posted by Bob on March 9, 2008, 6:19 pm
Appreciate any helpful thoughts on continuing saga on my Athlon 64 XP2.
After installing driver for the DLink WDA 1320, it operates fine until I
turn off the machine twice. The first time I turn it off, the system
recognizes the wireless connection, but the second time the wireless card is
no longer seen by device manager.
Called DLink support. The said try another slot. Again, as with the other
slot, it recognizes the card upon booting twice but third time it does not.
I doubt this is hardware problem. Any ideas why doesn't see the hardware
dependably each time I boot it up?
thx
bob
> card
> turn on the PC.
> kids?
> thanks
> bob
Posted by Jeff Liebermann on March 9, 2008, 8:17 pm
Weird. I'm not so sure it's not hardware. Any possibility it's a
heating problem? After it fails to recognize the card, unplug the
machine and let it cool down. Note that I said *UNPLUG* the machine.
The machine has WOL (wake on LAN) which keeps the power applied to all
networking cards even when the power is allegedly turned off.
Posted by Bob on March 10, 2008, 1:09 am
Jeff
good thought but can't be heat - after leaving the machine off all night it
fails to recognize the card in the am
I'll try my luck with tech support again. They will probably ask me again
to try it in a new slot
thx
bob
Similar ThreadsPosted
why is wireless networking card not recognized after PC turned off ? March 8, 2008, 9:29 am
radio turned off or card broken? June 10, 2006, 10:26 pm
USB Wireless Adapter not recognized May 17, 2005, 6:47 am
turned on WPA but network stumbler says WEP?! December 2, 2004, 9:37 pm
HELP: turned on WEP, and range plumetted December 29, 2004, 6:21 pm
Linksys, WEP turned off for some clients? August 26, 2005, 8:09 am
Finding APs with SSID broadcast turned off? December 8, 2005, 6:20 pm
Netgear USB Adapter not recognized April 12, 2005, 3:22 pm
Linksys wmp11 not recognized by windows xp November 11, 2004, 9:38 am
BUFFALO WLI-U2-KG54-AI USB adaptor stopped being 'recognized' February 15, 2007, 11:45 am
wireless networking December 24, 2004, 2:26 pm
new to wireless/networking April 2, 2006, 5:00 am
Wireless networking ? December 29, 2007, 5:07 pm
wireless networking guide February 10, 2005, 2:57 pm
wireless home networking February 22, 2005, 4:28 am
