Wireless Networking why does speed vary?
Subject Author Date
why does speed vary? avalanche* 03-20-06
|--> Re: why does speed vary? Frazer Jolly Go...03-20-06
Posted by avalanche* on March 20, 2006, 9:08 pm
Maybe silly Q. Why doees speed from my router vary from 54 (which I'm
sure is wrong) down to 1.0?
]Brad
Posted by Frazer Jolly Goodfellow on March 20, 2006, 9:34 pm
> (which I'm sure is wrong)
802.11g operates at a maximum of 54Mbps - so why do you think it is
wrong?
> down to 1.0?
Wireless LAN speed is dynamically adjusted by negotiation between the
end points to try to maximise speed whilst maintaining a reasonable
signal quality, hence acceptable error rate.
Variation between 54Mbps and 1 Mbps is excessive if the end points
are physically static, and suggests there is an interference problem.
Posted by Jeff Liebermann on March 21, 2006, 12:56 am
It's either interference from some other 2.4GHz device, or you have an
old buggy version of Intel Proset that does that without much
provocation. In theory, if the access point detects any transmission
errors, it will reduce the speed until the errors go away. If you
don't like this feature, you can set the wireless speed to whatever
you find amusing in the wireless access point web based setup utility.
However, if it really is interference, you'll be sending or receiving
errors instead of data.
# Jeff Liebermann 150 Felker St #D Santa Cruz CA 95060
# 831-336-2558 jeffl@comix.santa-cruz.ca.us
# http://802.11junk.com jeffl@cruzio.com
# http://www.LearnByDestroying.com AE6KS
Similar ThreadsPosted
why does speed vary? March 20, 2006, 9:08 pm
Checksum failures vary from BTS to BTS October 11, 2007, 2:24 am
Problem understanding why internet bandwidth speeds vary with usb wireless gear August 9, 2005, 11:48 pm
Wired speed: excellent -- Wireless speed: like an 80s modem (tops). October 7, 2006, 6:05 pm
Rod Speed FAQ July 9, 2006, 3:48 pm
speed August 11, 2006, 11:14 am
WEP vs WPA in terms of speed November 4, 2004, 1:10 pm
Transfer Speed? November 24, 2004, 6:11 pm
Speed decreses.... December 23, 2004, 4:45 pm
802.11g - Max speed in ad-hoc mode ? January 24, 2005, 10:31 pm
Is there a way to increase speed October 7, 2005, 5:43 pm
Slow speed April 2, 2006, 12:57 am
Download speed September 8, 2006, 4:28 pm
Only get half my speed April 4, 2007, 5:42 pm
RE: Only get half my speed April 5, 2007, 1:21 am
