There are two DSL lines on my property and they both work fine but each on each side of the yard.
I decided to run them together in a single CAT5E cable to my two DSL modems using 4 wires of one DSL line and 4 wires for the other one.
One line works perfect until I connect the other 4 wires for the 2n line then each DSL line dies! I can connect one or the other but not both. I would like to know why?
Sure I can run two separate CAT5E cables and wire them to 568A or B standards but would I dont see why I couldnt run each DSL line in the same cable?
Thanks! Thomas Redman Los Angeles, CA
