I've got a D-link DI-713P wireless router which is now discontinued and no longer supported by D-link, just my luck.
This router was working just fine and then all of a sudden I can't get online, not even while hard-wired into the router. When I hook into my cable modem direct and bypass the router, I can get online just fine so I know the problem is the router.
When I try IPCONFIG (I'm running Win2K)I see that the router's IP address isn't shown. When I manually enter it into my TCP/IP's properties menu, it still doesn't work. I can't access the router's setup page either. D-link's tech support was utterly useless. I've tried resetting the router and switching ports and nothing works.
Can someone please give me some direction here as I am on the verge of just buying a new router altogether.
Thanks.
