Which of these is a good small hotel travel wireless router?
Get yourself a cheap firewall/router and use both computers at the same
> time. You do need to check that the hotel is not using the same numbers > as you firewall/router is dishing out. 10.255.255.x would work as good > as anything for your firewall/router to dish out. Most devices and most > prople use 192.168.x.x You could get away with using 1.0.0.x but you > are not supposed to as they are reserved numbers.
What do experts recommend for a compact travel hotel router/firewall? I googled and found these but do you recommend any one in particular?
Unfortunately, none seem to be USB powered, so that means yet another power supply for the business traveler! :(
  • D-Link DWL-G730AP
  • Linksys WTR54GS
  • 3Com OfficeConnect 11g
  • Belkin F5D7233
  • Asus WL-530g
  • Netgear WGR101
Is any one brand or model preferred for your typical business traveler who values compact size and as few power supplies and cables as possible?
Mike S.
I use this (none of the above, works with ethernet, but also has a dialup modem in it)...
Peter Pan
Mike S. wrote: ...
The WGR101 comes w/the smallish power wart and a length of cat6 all bundled up in a pretty compact (8"x6") vinyl case. I've used it for about a year and a half now, mostly in hotels in North America and Asia.
Pros:
- small, lightweight
- dead-simple instructions (config card in case)
- supports single & multiple connections (great for work sessions)
- WPA easy to set up
- throughput was very good
- Works well w/the ISP subcontractors used at hotels I frequent
Cons:
- runs hot
- range ain't great (but, heh, a hotel room is fine)
- mode switch on side is just crap (am I on "1?" or is that "3?."
Lastly, it has dropped connections periodically when using one hotel's service. Dunno why or whether it was the router's fault. Elsewhere, worked w/o a hitch.
It works well and is dirt cheap. Would I buy it again? Can't say since I don't know what the market's doing today but I depend on it and it gets the job done.
fwiw,
-Craig
Craig
Neill Massello
