Does W98SE have TFTP included, or do I need a separate utility?
Got the WHR-G54S bin file ready, but no TFTP available....
Louis Ohland hath wroth:
Yes. However it's a DOS program that must be run from the command line.
If you want something free and Windozed, try:
Duh. I didn't see the Windoze 98. The command line version I mentioned only comes with W2K and XP, not W98SE.
The Wierd Solutions TFTP client will work on 98SE.
Other TFTP clients that work on 98SE are: ftp://ftp.linksys.com/pub/network/tftp.exe (Windoze)
Hi, Did you try tftp /? command? If nothing comes back you don't have it. You can download it. And flashing with tftp needs several tries. I got time out messages and finally success message. Then wait for a while to be sure. Good luck, Tony
