WG511 cards and AES
I've been unable to get either my Netgear WG511v1 or WG511v2 cards to connect to the router through AES level encryption using the Netgear connection utilities. I also downloaded and installed the latest drivers/connection utilities from Netgear support. They will only connect using WZC. Anyone having such an issue with their WG511 cards? What resolutions have you come up with?
nusr
Taking a moment's reflection, nusr mused: | | I've been unable to get either my Netgear WG511v1 or WG511v2 cards to | connect to the router through AES level encryption using the Netgear | connection utilities. I also downloaded and installed the latest | drivers/connection utilities from Netgear support. They will only | connect using WZC. Anyone having such an issue with their WG511 | cards? What resolutions have you come up with?
Yes ...
mhicaoidh
