Just switch the network to WEP. Decent security on the network is kind of pointless: if the data is sensitive encrypt it before you send it across the network; if it isn't who cares? While it's possible that somebody could attack your network and do "bad stuff", do you really care? (since you can easily deny it because your network is known to use broken security)
Any particular maker and model number? Just curious in case there's an access point compatibilty issue.
If the driver didn't come with the Eagletec SD card, then it can be had from a 3rd party. See:
*THINK* it includes WPA2 but I can't tell for sure from the data sheet.
Any particular version of PocketPC? Windoze Mobile 2001 -> 2003, Windoze Mobile 5.0, CE 1.0 -> 5.0, etc? Any particular maker and model handheld?
Driver only. WPA was specifically invented to patch together the mistakes made in WEP encryption. It was to be a software or firmware only change and does not require any hardware support or changes. (Not necessarily true for WPA2 which might require a dedicated AES encryption chip).
Yeah, but that depends on how the thing's implementing it. The WiFi SD card is kind of cool, but I have a feeling it horribly breaks all recommendations in order to get it to work!
Sorry, but I thought Eagletec referred to your Pocket PC. What's the model number of the SD card? That said, an SD WiFi card is unusual enough that there's a good likelihood that there is no updated driver, but that doesn't mean there never will be.
