Hi all.
Here's an interesting one.
I've recently had problems with the internal wireless NIC on my Gateway laptop. The desktop pc gets on the wireless network no prob. Suddenly the laptop won't. I disabled all the startup programs to check for conflicts. I disabled the WEP security on the Linksys Wireless router and then the laptop can connect with the network and the internet. Enable the WEP and it won't. I get the "limited or now connectivity" error message. I set the WEP key in the advanced network settings. Still no luck. I checked the WEP key in that same dialog and it doesn't look like there are enough characters entered. I entered the 13 ascii characters that xp tells me I must have, but when I go back in there are only 8.
Any ideas?
Thanks. JB
