I have a WDS (Wireless Distribution System) setup at Home. router 1) is primary Buffalo , router 2 ) is Linksys both running Tomato firmware Have a Thinkpad laptop.
Setup works great except with 1 hitch. My Laptop's Wifi card does not automatically switch to the strongest AP signal. IT still holds on to the original router's connection and so Im getting low conn speeds if I move around. I tired setting the roaming to aggressive but no luck.....
Thoughts?
