I just wasted a great deal of time and money and very nearly lost my client trying to get Build 13064 (VINT std) to work reliably on a Linksys WRT54GS v1. Symptom was the router spontaneously restarting every few minutes, taking the wireless network down, driving my client up the wall.
Finally solved the problem by flashing Build 12533.
My mistake was trusting the DD-WRT Database recommendation of Build
13064. Only afterward did I find it's a known bad build for this hardware!This is crap, a really dumb problem that needs to be fixed without delay. But it probably won't be -- Powers That Be don't seem to care.
MORAL: If you're going to use DD-WRT, be *sure* to first check the appropriate DD-WRT Forum to see what's been working well for your particular hardware:
