I have setup a WAP54G for a school environment where there are outside portable unit being used as classrooms. They outside units were not receiving enough of a signal so I purchased a WAP54G to be setup as a repeater to a WRT54GS.
I setup the WAP54G in repeater mode, using the MAC address from the WRT54GS, using the same channel as the WRT but a different SSID (according to Linksys directions, this is OK). Now, should I have the outside users connect to the WAP54G or the inside WRT54GS? When they connect to the WAP54G it does not give out and IP address. I assumed they weren't setup to go do. So, I set the users to connect to the inside WRT54GS which does not seem to help the signal strength?
Any suggestions would be appreciated.
