Although the initial problem was solved, now that the unit has reset itself I am now where I was a year or so ago, though I don't remember how I solved this one.
In review, my setup is DSL modem connected to hub. Connected to the hub is a wired PC and the wireless Access Point.
I had this setup so that I could gain internet access via the Access Point - hub - dsl modem. This would work even when the other PC was off, no internet connection sharing going on.
I can talk to the Access Point if I connect a laptop and wire it into the hub, then set the IP address of the laptop to be something like
192.168.1.5.
I experimented with various combinations of IP. DNS and DHCP settings to no avail.
If I run ipconfig from my wired machine I get this:
Windows IP Configuration
Node Type . . . . . . . . . . . . : Unknown IP Routing Enabled. . . . . . . . : Yes WINS Proxy Enabled. . . . . . . . : Yes DNS Suffix Search List. . . . . . : cruzio.com
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : cruzio.com Description . . . . . . . . . . . : Intel(R) PRO/100 S Network Connection Physical Address. . . . . . . . . : xxxxxxxxxxxxx Dhcp Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IP Address. . . . . . . . . . . . : 63.249.86.240 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 63.249.86.1 DHCP Server . . . . . . . . . . . : 63.249.95.8 DNS Servers . . . . . . . . . . . : 63.249.95.8 63.249.95.9 Lease Obtained. . . . . . . . . . : Sunday, July 30, 2006
4:50:52 PM Lease Expires . . . . . . . . . . : Sunday, July 30, 2006
8:50:52 PM
What settings should I place into Access Point to allow internet access to wireless pcs?
