On Fri, 30 Jun 2006 01:59:22 GMT, John Navas wrote: : On Thu, 29 Jun 2006 21:17:30 -0400, Robert Coe wrote in : : : : >On Sun, 18 Jun 2006 14:52:25 -0400, Robert Coe wrote: : >: The other day I upgraded the firmware on one of my Linksys WAP54G access : >: points from 2.08 to 3.04. I did it remotely from a PC in another building. All : >: went well until the upgrade was declared complete, whereupon the access point : >: became totally unresponsive. It continued to serve wireless clients, but could : >: not be managed. Even manually rebooting didn't help. I finally had to swap it : >: out, reset it to factory settings, and reconfigure it from scratch. (The : >: upgrade did "take"; the displayed firmware level is now 3.04.) : >: : >: Just to make sure it wasn't a fluke, I did the same thing to another WAP54G : >: over the weekend, from home. Now I can't contact that one either, so I guess : >: I'll have to swap it out tomorrow and reconfigure it from scratch. : >: : >: Is this a known problem? Is there a workaround (installing an intermediate : >: upgrade, for example)? I've got about a dozen more WAP54Gs I'd like to : >: upgrade, and swapping them all out would be a pain. : : >Just on the off chance that anyone is still interested, I finally figured out : >the answer to this problem. The upgrade changes some, but not all, of the AP's : >settings. The critical one changed is the default gateway, which is set back : >to 192.168.1.1, even if the AP is set to get its IP settings via DHCP. So if : >you're trying to manage the AP from a computer on a different subnet, the : >upgrade causes the AP to lose the ability to respond to your commands, because : >it can no longer find you. A reboot doesn't help; all you can do (short of a : >reset to factory settings and full reconfiguration) is to log into a computer : >on the right subnet, set the AP to a static IP, change the default gateway to : >the correct value, and then set it back to DHCP. Damn. : : The gateway isn't a factor in the browser interface, which is actually : just its LAN (as compared to WAN) address. The gateway is for routing : traffic off the subnet; e.g., to the Internet.
Well, ah, no. The WAP54G is an access point, not a router. It has only one address.
: Also, DHCP (client) has no bearing on this, since that's used to set the : WAN (not the LAN) address.
See above.
: Finally, the router doesn't need to "find you" -- you need to find the : router.
I (well, my computer) knew where the access point was. But the AP couldn't respond because its gateway address was guffed.
: My guess is that the LAN address is what's being changed, so you aren't : able to access it at the old LAN address. If you know the new LAN : address, use that, manually configuring the PC to the same subnet : temporarily if necessary.
Your guess is a bit wide of the mark, but thanks anyway.
