WAP54G connectivity ?
Threaded View
I am using a WAP54G, firmware 2.07, in repeater mode of a WRT54G. I am
accesing the WAP54G via an IBM Thinkpad T40 (miniPCI cisco card, and
Aironet Client Utility from Cisco, V 6.2.012)
This combination works nice, I have good signal from the WAP54G,
however there are "mini-cuts" to the connectivity, of no more than
let's say one second. That's enough for my machine to show a 'network
down' message, that automatically turns into 'network up', however for
certain applications I use that 'down-1-second-later-up' thing is
enough for cancelling them (for instance if I use streaming of any
kind, like the popular skype VoIP application). This situations
happens in average once every 10 minutes.
Something else: If I choose to connect directly from the T40 to the
WRT54G ( in the exact physical location the WAP54G lies ), that does
not happen, so I am pretty sure this is related with the connectivity
between either my T40 and the WAP54G, or the connectivity between the
WAP54G and the WRT54G.
Maybe this could be resolved seting up some timeout parameter
somewhere. Using the web based utility of both the WTR54G and of the
WRT54G I do not see any parameter to adjust ....
Other possibility. May be I have to place the WAP54G much closer to
the WRT54G to avoid this behaviour ....
May be because the WRT54G and the WAP54G are connected to 54Mbts/sec
and that is a much more sensitive connection ...
Any help will be appreciatted.
Regards
Andres
Re: WAP54G connectivity ?
"Andres Dagotto wrote in message>
am
'network
for
connectivity
the
> Regards
> Andres
Seems the common fix for the 10 minute problem is to uncheck "Use
802.1x authentication" under the wireless network tab called
Authentication.
> Hi,
I
> am
and
> 'network
> for
the
does
> connectivity
> the
the
to
54Mbts/sec
> > Regards
> > Andres
> Authentication.
Just noticed you were using a cisco client utility. If let windows
control the connection is unchecked then
the last answer probably does not apply.
One other thing you might check is to see if you are using PSP (Power
Save Polling)
It will be in the driver config. PSP allows the adapter card to go to
sleep to save power.
It only wakes up to listen for the next Beacon time to see if  the AP
has anything for it
then it goes back to sleep. You can test this by putting in CAM mode.
> > Hi,
>  I
>  am
>  and
>  'network
>  for
>  the
>  does
>  connectivity
>  the
>  the
>  to
>  54Mbts/sec
> > > Regards
> > > Andres
> > Authentication.
> Save Polling)
> has anything for it
Thanks for your answer.
1- Correct, I am running the Aironet Client Utility (ACU) from Cisco
2- In Wireless Status -> Properties -> Wireless Network -> Wireless
Network Properties -> Authentication,  the 802.2x authentication is
not selected
3- I was/am using Constantly Aware Mode (CAM)
Any other ideas ?
Once more, thanks for your help
"Andres Dagotto"  wrote in message
> > > Hi,
> >  I
> >  am
> >  and
> >  'network
> >  for
> >  the
> >  does
> >  connectivity
> >  the
> >  the
> >  to
> >  54Mbts/sec
> > > > Regards
> > > > Andres
> > > Authentication.
> > Save Polling)
> > has anything for it
> not selected
> Any other ideas ?
I am assuming you are running Windows XP and not knowing
exactly what the Wireless Zero Config does in the background
while using a different utility or if it even starts at all, I would verify
that
the service is not running. If it is, stop it and try again. If it is
running
it will probably start up after each reboot.
You can do this by Start/Run type in cmd then at the prompt type
services.msc
Look for the WZC service and see if it is started, is so highlight,
right click and select stop.
> that
> running
> services.msc
Thanks. The service was running, and I had stop it. Let's see what
happens ...
The startup time is 'automatic'
I read you do not know what it does, but probably you have a rough
idea on that, right. So, what does the WZC do ?
Regards
Andres
On 4 Dec 2004 17:24:12 -0800, Andres Dagotto spoketh
>> that
>> running
>> services.msc
>happens ...
>Regards
>Andres
WZC is microsofts generic wireless client software. It manages
connections to wireless networks in the same fashion that
vendor-specific client does.
Lars M. Hansen
http://www.hansenonline.net
(replace 'badnews' with 'news' in e-mail address)
Andres Dagotto wrote:
> Hi,
> Regards
> Andres
A friend of mine has one of these, and it's the biggest pile of shit I
have seen, it's totally useless if you want to host a website on your
LAN, and use the routers port forwarding, as it falls over after a hour
or so, making the site unavailable.  firmware updates, and playing with
settings has done nothing to cure these problems.  The wireless range is
also pretty dire.
Needless to say ebuyer washed their hands, and Linksys are about as
usefull as a chocolate fireguard..
Frankly I expected better from a cisco company, if anyone is considering
one, don't...  Pay a bit more and get a Draytek Vigor...
"Black Shuck"
> also pretty dire.
I own a wap54g, and I honestly have had very dependable service from it so I
cant complain about the product. What I do think, is that there are still
some interoperability problems between hardware of various vendors. In my
best opinion, use the same hardware for the Ap as you do the adapters and
you will usually be better off. The wifi alliance certifies equipment
according to IEEE standards and alot of companies go outside the
standards...........i.e like 108 speeds and turbo etc
My experience with Linksys products has been also good so far
(crossing fingers).
Going back to my 'down-1-second-later-up' problem, looks like turning
off the "Wireless zero config" service helps. I will continue testing
this.
Airhead, any idea on what this service does ?
Regards
Andres
On Sat, 04 Dec 2004 23:29:57 +0000, Black Shuck spoketh
You are confusing the WAP54G with another product. The WAP is a simple
access point, and doesn't have any router settings, port forwarding or
anything else. I have a WAP54G myself, and it is a very reliable and
stable product.
Lars M. Hansen
Site Timeline
