I just bought a Linksys WAP11 Access Point so my son could get online with his Sony PSP - it worked perfectly.
As with all hardware/software I get I check for available upgrades, and found a firmware upgrade to 2.05, which I downloaded and installed. Ever since then the WAP11 is as dead as dead can be. I cannot connect to it at all. I tried resetting it etc, and using the original IP address etc.
Then I noticed that the firmware upgrade was a US one!!! Can I fix this now - I doubt I can :o(
If the US firmware kills UK spec hardware, should there not be a fail-safe to stop you doing his kind of thing????
I am so fecked off now - The unit cost me =A323 delivered (NEW), so may as well throw it and get another one than go through all the hassle of sending it back etc.
Well, if anyone can help me fix this then I would very much appreciate it.
Thanks.
Demon :o(
