Won't work at all. When I ran the numbers, I ended up with a -5dB fade margin. You need at a minimum of +10dB fade margin to just barely work. I used:
Tx power = 15dBm Rx sens = -82dBm (for 11Mbits/sec) TX pigtail and connector loss = 3dB RX pigtail and connector loss = 3dB TX antenna gain = 8dBi antenna gain = 8dBi Fade margin -> -5dB which sucks.
