I have a PC dual booting Windows XP and 98SE. I need to connect to the Internet using a wireless connection. I have bought a EDIMAX wireless PCI card and this worked well under Windows XP using XPs own software. Unfortunately the software supplied doesn't support WPA under Windows 98SE. As the driver and connection software are separate I can't see any reason why I shouldn't use another vendors connection software. If you have a wireless connection running under Windows 98SE, what connection software are you using? My router is from 3Com.
- posted
18 years ago
