In the packet of Ralink 5370 there is a mini CD containing the drivers. The utility was missing. Who has for me this utility?
- posted
9 years ago
Ralink ?
They appear to have been bought up. []'s
Op dinsdag 23 september 2014 22:09:20 UTC+2 schreef Shadow:
That's are only drivers. I need Ralink Utility.
What on earth for ? All it shows you is available networks and signal strength. There are dozens of tiny freeware apps that do just that. BTW, please don't thank me, it makes me blush. []'s
PS quoting from memory, I once a RT61 PCI that came with the utility. I uninstalled it .... pretty useless, unless you like green.
You may already have it. It's called "APUI.EXE" and mine is in the "C:\Program Files\Ralink\Common" folder, although yours may be somewhere else. If it isn't there, you might try the download from MediaTek, which apparently bought Ralink.
The Windows versions are at the bottom of the page. They ask for your name and e-mail address, but they don't actually e-mail you the download, so you can probably enter anything you like.
Ben
