I have a 5220 Aircard (Verizon Wireless 1x, evdo access ) and have need to share it with multiple machines (e.g. personal machine, plus work VPN machine, they need to be separate).
I'm currently using an old laptop that's about to die. I'm looking for a replacement. I had tried a PCI/PCMCIA converter card and put that in my personal machine. However, about every 3 days or so, the card would wiggle loose enough to cause a hard bus lock up on the machine.
I'd consider a 'stompbox' (linksys style router with a pcmcia adapter to share the 5220), but I haven't seen any for less than what I could buy a barebones PC.
I could buy another laptop, but that'll run around $500-$600 for a barebones model, and if I got a power laptop, I'd be spending more.
I could try a barebones PC with another PCI/PCMCIA card, but then I'm stuck with uncertainty of stability of the PC to begin with, and with the uncertainty if the PCI/PCMCIA card might just wiggle loose every couple days from this new machine too.
Any other options I've missed? Or any different takes on the situation that may help?
