Hi,looking for advice or working configuration details..
I am trying to install a linksys wag354g wireless gateway to replace an existing btVoyager 205 ADSL modem. The modem is working fine, I can access the internet no problem, however when I setup the wag354g I cannot make a connection, I copied the settings from my own wag54g which works ok(BT Network, different provider)
viz: - encapsulation - RFC2364PPPoA VPI 0 VCI 38 Multiplexing LLC MTU Auto DDNS disabled NAT enabled
HOWEVER, the linksys leaflet tells me that multiplexing should be VC ???
Has anyone got a wag354g working on a BT Broadband service at all?
Appreciate any advice on this, thanks
