W2K and D-Link DSL-G604T hangs after 5 mins no matter which adaptor I use
Using this router my PC upstairs works fine with either the D-Link adaptor that came with the router or the cheapo unbranded one I bought on Ebay. Downstairs my other PC works for 5 mins and then the internet pages just stop loading even though the signal strength has not dropped. Even if I put the router one foot from the adaptor the same thing happens even though the adaptor software reports 100% signal strength. When I decided to access Windows Update (using my modem instead) I get an error that means update won't run. Any ideas? Thanks, Lee.
kettlecup
Some source of 2.4 GHz interference downstairs.
John Navas
do you have the manfacturer specific software installed on the faulty client? If so try disabling windows handling of the wireless connection.
feep
