"Tor Tveitane" wrote in news: snipped-for-privacy@individual.net:
VPN connections are router to router (hardware) VPN connection or software client to software server VPN connection (software) VPN connections like AT &T Extranet client and server software. Or Win 2K Pro workstation using IPsec connection to a Win 2k server that running IPsec as a VPN solution.
SSL is provided to a WEB site by a vendor like Verisign and allows a browser like IE to connect to the WEB site using a SSL connection session. Like you doing a bank transaction with your bank that has a Web Banking Service site.
Those SSL solution from a secuirty company like Verisign cost a pretty penny and are not cheap like $1,000(s) of dollars, in some cases $100(s) for cheap vendor.
I hear you can crack WEP. You most likely can do the same with WAP too but it may be a lot harder.
You may be able to get two workstations into a VPN session using IPsec = search Google.
