I have a desktop connected to a router via a cable and a laptop connected to the same router via WiFi. Both work fine with static IPs.
I've set up a VPN between the laptop and the desktop with the latter acting as a server.
The problem is that as soon as I open the VPN connection on the laptop it's Internet connection stops working (and resumes immediately after I disconnect the VPN).
This is my laptop ipconfig before VPN is connected. Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) PRO/Wireless 3945ABG Network Connection Physical Address. . . . . . . . . : 00-18-DE-B5-2A-F3 Dhcp Enabled. . . . . . . . . . . : No IP Address. . . . . . . . . . . . : 192.168.123.166 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 192.168.123.254 DNS Servers . . . . . . . . . . . : 212.150.49.10
192.168.123.254And here it is with VPN connected: Windows IP Configuration
Host Name . . . . . . . . . . . . : JACK-LAPTOP Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Wireless Network Connection:
3945ABG Network Connection Physical Address. . . . . . . . . : 00-18-DE-B5-2A-F3 Dhcp Enabled. . . . . . . . . . . : No IP Address. . . . . . . . . . . . : 192.168.123.166 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 192.168.123.254 DNS Servers . . . . . . . . . . . : 212.150.49.10 192.168.123.254PPP adapter Home VPN:
Connection-specific DNS Suffix . : Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface Physical Address. . . . . . . . . : 00-53-45-00-00-00 Dhcp Enabled. . . . . . . . . . . : No IP Address. . . . . . . . . . . . : 192.168.123.164 Subnet Mask . . . . . . . . . . . : 255.255.255.255 Default Gateway . . . . . . . . . : 192.168.123.164 DNS Servers . . . . . . . . . . . : 212.150.49.10
192.168.123.254Any ideas, guys? Thanks
