I am taking a shot in the dark that someone here can help.
I am new to IBM and having difficulty getting the ATT Global Network Dialer (VPN) to work over my wireless system.
If I Right Click "My Network Place" and go to Properties and "Right Click" on both my AGN Virtual Network Adapter and Wirless Network Connection - shut off "Net Firewall Service", reboot and then turn the service back on - I can log in my VPN - *But only once*.
If I then diconnect, and try to reconnect I run into the same problem where the VPN cycles through trying to authenticate over and over again.
I am running through Bellsouth DSL with a 2WIRE DSL Modem and Wirless Router. The T41p Thinkpad is picking up the 11b signal at good to excellent strength.
Currently under the VPN Configuration I have two odd things checked in the "Misc" section:
1) Negotiate UDP Encapsulation with VPN serverfor NAT Transversal 2) Authenticate via HTTP for IPSec 3) MTU is set at "Default" which is reccomended. I did some basic pinging w/o fragmentation loss at 1464 when I was playing around last night.I set up my own home network and know enough to make me dangerous, but in no way am and expert - so any help would be appreciated.
Thanks in Advance
