warner snipped-for-privacy@hotmail.com hath wroth:
OK, 250 msec per ping. That means the burst of crud is about 1 second long.
It looks fairly repeatable. There'a also a small glitch about 750msec before the 1 second burst that also seems repeatable. 1 second duration is a LONG time for a battery saver, so that's out. It's too fast and too long for radar. Whatever it is seems very periodic.
It sounds roughly like the pattern of a data burst from some transmitter. My guess would be a wireless weather station, wireless burglar alarm, or cordless phone system that updates the handsets. It can also be coming from outside in the form of a SCADA telemetry transmitter from some utilty service, or data collector. Is anyone doing any Zigbee work in the area?
Another possibility is a cordless mouse on 2.4GHz. One of these (I forgot the model) has a feature where if the mouse walks away, an alarm goes off in the computer. It's necessary to have the mouse transmit something periodicially, which might be the source.
I know I'm being fairly vague but that's the best I can do from here without knowning whats in the vicinity. The next step would be to drag out the spectrum analyzer and directional antenna, which is probably more than you want to attempt. If you have some amateur radio operators nearby, you might ask for help.
Try this test. Take a cardboard box and cover it with aluminum foil on all but one face of the box. Leave the lid functional. Don't worry too much about sealing the lid edge seams. Put the access point inside the box and rotate the non-covered side in 45 degree incriments to obtain a crude impression of the direction of the intereference source. Don't forget to try up and down direction and moving the access point around. I don't know if this will really work, but it's the best I can think of.
If I think of anything else, I'll post it. (I have the feeling I'm missing something obvious).
Windoze apparently truncates ping times. That's why I like to use fping. There's additional resolution, more features, and it numbers the packets so I can see if any disappear. It's fairly difficult to ruin a simple diagnostic like ping, but Microsoft managed it nicely.
Ok, so much for the WPA re-keying theory. If it's not the computer getting busy (I assume you checked with another machine), what's left is: RFI (radio interference) Broken BT HomeHub Alien communications from nearby crop circles.
