Hi I'm have a Gateway MT6705 running Windows Vista Home version. I can't connect to my office's secure wireless Windows XP Wi-Fi network. It sees the network but can't connect. Has anyone else run into the same problem? Supposedly it should try to connect and then ask the user for the password, ie, no prior need to give the network the MAC address on of the card. It should give this info to the network when it connects. I called Gateway and they said for some reason Vista is not backwards compatible with XP in this matter. Is this true? Any input would be appreciated.
- posted
16 years ago
