Vista and Apple Airport extreme
I have a Vista Home premium on a wireless connection through a Edimax AP - which connect no problem.
I am due to receive a new Macbook Pro in the next few days and I am also looking at getting a Airport Extreme (mainly because of the USB port).
Does anyone know if there are any probles with Visat connecting through a Airport Extreme?
thanks
Clive
Clive
On 27 Feb 2007 01:07:15 -0800, "Clive" wrote in :
Vista should work fine if you set things up properly.
John Navas
If you're planning to run Vista on the Mac, take a look at Chris Breen's Macworld article on the subject. Apparently Vista worked with his Mac Pro's built-in AirPort, even without installing the Apple drivers; but he didn't specify whether his AirPort hardware had been enabled for
802.11n.
Neill Massello
